the reference manual says that NC_ST_WRITE_SUCCESS state transitions to true when the queue is empty, but it never does, do you know why?
The NC_St_Write_Success should transition to true when the queue is cleared. Use the nc_get_Attribute function to check to see if there are any entries still pending to be written on to the bus.
Are you doing a "Periodic Transmit" and what is the present write queue length?
(4,418 Views)
