using NI-XNET session with FGV
I want to use NI-XNET session in a FGV and I've got the following error : 0xBFF6309C.
I also try with Global variable same error.
it's not possible to save XNET session ?
I'm using Labview 2012 SP1 and NI-XNET 1.7
Thank you for your help
JP
Message 1 of 10
(9,069 Views)
Can you provide an example of your code and the screeenshot of this error?
Paolo_P
Certified TestStand Architect
Certified LabVIEW Architect
National Instruments France
Message 2 of 10
(9,046 Views)
BFF6309C is
Error -1074384740 occurred at an unidentified location
Possible reason(s):
NI-XNET:  (Hex 0xBFF6309C) You called XNET Clear for the session, then tried to perform another operation. Solution: Defer clear (session close) until you are done using it. This error can also occur if you branch a wire after creating the session. Solution: Do not branch a session to multiple flows in the diagram.
I assume a screenshot of this error is not needed
Message 3 of 10
(9,043 Views)
Which LabVIEW are you using?
Which NI-XNET driver?
Can you attach a IO-Trace log file which lists the XNET function calls?
thanks
Message 4 of 10
(9,035 Views)
A simple three icon FGV with XNET is working fine for me, so there shouldn't be a fundamental problem with it.
Could you post your VI (or contact National Instruments support)?
Christian
Message 5 of 10
(9,032 Views)
I have the same problem, did you find the solution?
Message 6 of 10
(8,416 Views)
as Ceule wrote please add a VI so that we can reproduce your issue
Message 7 of 10
(8,405 Views)
there is no solution, the xnet session is not maintained in memory if the FGV is not called in a Principal VI.
In my case the FGV is called by TestStand Steps and it works.
hope this help
Message 8 of 10
(8,397 Views)
Message 9 of 10
(8,380 Views)
相同的问题......
JP_V 已写:
JP
Message 10 of 10
(7,374 Views)
