BLT for LabVIEW (Build, License, Track)
Where are the tmep files?
When I download the installer and start it, files are extracted. When I cancel, they are not removed.
Where are they so I can remove them manually?
(5,099 Views)
The installer is a WinRAR self-extract archive which extracts in the %temp% folder (creates a subfolder "RarSFX0" under %temp% and extracts the installer files into that folder). If you cancel the extracting process or the installation process, this temporary folder gets deleted. Same if you complete the installation process to the end.
You should not have to delete those files manually.
Please mark this reply as Solution if this answers your question, or let me know if you have any question.
Regards
Matthias Baudot | Software Architect | Founder & Owner at STUDIO BODs | DQMH® Consortium Board Member & Trusted Advisor
STUDIO BODs     LabVIEW Champion     Certified Professional Instructor     DQMH Trusted Advisor     DQMH Consortium Board Member     GCentral Sponsor
 Check out my LabVIEW presentations and videos!
(5,094 Views)
