In the 2013 Biomedical Toolkit, the Biosignal Viewer provides many new features for the annotation, virtual channels, measurements, and save functions.
Main New Features and Improvements
Using Annotations
Click Annotation in the Biosignal Viewer to open the Annotation dialog box. Use this dialog box open to filter, add, edit, and delete annotations.
Filter Annotations
In the Annotation dialog box, you can filter annotations by set or name or according to further advanced options, including time range and channel. The filtered annotation results appear in the Results list and on the graphs.
Go to Annotation Plot
In the Annotation dialog box, select an annotation row in the Results list and click Go To to locate and plot the selected annotation on the graph. You can use <down> or <up> to locate the next or previous annotation, respectively.
Add an Annotation
Right-click the graph and select Add Annotation Here to display the Add Annotation dialog box. In the Add Annotation dialog box, you can set the Name (Description), Snap to Channels and Set properties of an annotation.
Edit/Move an Annotation
In the Annotation dialog box, double-click the row you want to edit from the Results list. Next, use the pull-down menu to select one of the existing annotation types. Alternatively, you can click Custom Annotations to add a new annotation type.
You can also right-click an annotation to activate its short-cut menu and select Edit Annotation.
Right-click an annotation to activate its short-cut menu and select Move Annotation. When the annotation turns red, you can use <Right> and <Left> to change the position of this annotation.
Delete an Annotation
In the Annotation dialog box, click Delete to delete the selected annotation from the Results list. You can also right-click the annotation on the graph and select Delete Annotation to delete it.
Add Virtual Channels
Click Channel Settings in the Biosignal Viewer to open the Channel Settings dialog box. The new Set Virtual Channels control is shown in the Channel Settings dialog box.
Click this button to open the Set Virtual Channels dialog box. The dialog box options is the same as the virtual channel settings of the Biosignal Logger. Refer to the Biosignal Logger help for details.
Measurements:
In 2013, you can add two markers to perform such measurements as Delta T/Y, Max/Min and Statistics.
Save
In 2013, the Biosignal Viewer supports the following saving options:
Click Save in the Biosignal Viewer to open the Save File dialog box. Note: Save is only enabled if the TDMS file you view was created by Biomedical Toolkit.
Save to the Currently Viewed File
Saving to a New TDMS File
sounds very powerful!!! when wil the 2013 version be released? thankyou![]()
It will be released in NI Week 2013! Just wait for several months.
Thanks!
ZJ Gu
