The Biosignal Logger utilizes analog input channels from National Instruments hardware, such as NI ELVIS II or NI data acquisition (DAQ) hardware, to acquire signals.
Complete the following steps to measure signals by using the Biosignal Logger.
| Note If you use NI ELVIS II, you must ensure that the output channels and the input channels on the prototyping board are directly connected using metal wires. |
| Note You can use the File Format Converter to convert the log file this application saves from a .tdms file type to another file type. |
hi, i have a question about this tool, when i'm configuring the input range there is just two options, -+10V or +-5V, i'm working with ni pci 6221 adquisition card and i need to use +-0.2V range to achive microvolts accuracy, so, what i have to do?, may i solve this problem with sensitivity value?
thanks for help.
Sensitivity is for explaining the physical unit. You could use the Biomedical Startup Kit Source Code Version to modify that value.
Thanks!
ZJ Gu
