In the biomedical signal processing field, software and hardware equipment generate different types of data files. The File Format Converter is a LabVIEW application that converts files of different file types for use in various applications, including importing the popular EDF file format.
This application includes the following features:
Complete the following steps to load data of one file type and convert specific signals from that data to another file type.
| Note The Output Path automatically populates with the same folder path as the Input Path. You can click the Browse button next to the Output Path to select a different location to save the converted file. |
| Tip Click the Add ALL button to select all the channels in the data file to convert. |
MATLAB® is the trademark of The MathWorks, Inc.
Hi
I downloaded the biomedical toolkit really for the purpose of the file format converter tool. I create alot of applications where I store data in .tdms but analyze it in Matlab. So the tool's ability to convert from .tdms to .mat is really of interest of me. I downloaded the toolkit and tried to convert a .tdms file to .mat but upon the selection of the output format I am only able to select .tdms. Is the functionality to convert to .mat not available in this release?
Hi spsuamin,
You are right that this version only supports TDMS. But soon we will support MIT-BIH Database , MAT. Please wait a moment.
Could you please provide me with a link of where I could download this from please. Thanks
