Biomedical User Group Discussions
CSV to physiobank conversion
Dear all
I have the following problem using Biomedical workbench specially file conversion
We have an ecg-maschine which has an csv output, our external software needs physiobank file to import
Unfortunately the conversion with the biomedical workbench into physiobank “changes” the ecg, this is not happening if I am using TDMS or EDF but I need physiobank
This is the original csv opened in the biomedical workbench viewer (test-csv.jpg)
After conversion to physiobank: there are spikes (test-physiobank.jpg)
After TDMS (test-tdms.jpg): like the original csv
Does somebody has an idea what is the problem
Matthias
(4,836 Views)
Wow, almost a year and no response, I also had non-resolved issues with Biomedical Toolkit file conversion.
(4,408 Views)
Hi
I have the same problem as you with the ECG conversion. Do you have foud a resolution or another way to do it
Thanks for your help
Matthias
(1,044 Views)
