Biomedical User Group Discussions
Check out the new Biomedical Start-up Kit 2.0
Version 2.0 of the Biomedical Start-up Kit is available for download now!  More information about the toolkit is available here:  http://zone.ni.com/devzone/cda/tut/p/id/9037
This kit contains the following applications:
  • File Format Converter (EDF, EDF+, MIT-BIH databases, WFDB databases from physionet.org, etc.)
  • Biosignal Logger
  • Online Biosignal Noise Reduction Data Logger
  • ECG Feature Extractor
  • Heart Rate Variability (HRV) Analyzer
  • Analog ECG Generator
  • Noninvasive Blood Pressure (NIBP) Analyzer
We are aware that a large community of our users are doing biomedical research and teaching using LabVIEW and we have recognized that sometimes the terminology and naming of our functions, as well as just the raw breadth and depth of the functions provided with LabVIEW sometimes creates too steep a learning curve.  The toolkit was designed to improve the awareness of LabVIEW's applicability (and strength) in dealing with biosignals, and at the same time, helps get someone new going very quickly by providing ready-to-run mini applications to show what can be done.
So...that said:  in addition to the suggestion about making the source code available (which we will certainly discuss) where would you like this toolkit go?
Message 1 of 8
(8,962 Views)
how can you download this kit. i tried  but its not happening. can u help..
jigyasa
Message 2 of 8
(5,181 Views)
I tested it just now. It is okay. Could you please check again?
Thanks!
Zhijun Gu
Message 3 of 8
(5,181 Views)
Is there any one who tried the file converter of the biomedical start-up kit? I installed it on two machines and found it can only convert files to tdms format. The other three options were disabled? Any ideas?
Thanks.
Wei
Message 4 of 8
(5,181 Views)
Yes, you are right that the current application only supports output to TDMS file. Other features are not available now. We will provide soon, Wait a moment!
Message 5 of 8
(5,181 Views)
Is there any plan to add csv format in the target file format? This can allow almost all applications to read the data created by LabVIEW.
Wei
Message 6 of 8
(5,181 Views)
CSV format could be obtained indirectly.
We have a TDMS plugin for Excel : http://zone.ni.com/devzone/cda/tut/p/id/4906
You could load TDMS file in Excel first, then save as "CSV" in Excel.
In our plan, File Format Converter will support exporting to CSV soon. Wait a moment!
Hope this is helpful!
Thanks!
Message 7 of 8
(5,181 Views)
Now CSV is supported! Please update in http://zone.ni.com/devzone/cda/tut/p/id/9037.
Thanks!
Zhijun Gu
Message 8 of 8
(5,181 Views)
