Biomedical User Group Discussions
Check out the new Biomedical Startup Kit 2.1 with Source Code!
Hi All,
After a long time, we are glad to release a new version of Biomedical Startup Kit 2.1! It fixes many bugs and also adds some new feature as requested.
The new features in Biomedical Startup Kit 2.1:
  • The File Format Converter supports exporting MAT, MIT-BIH, and CSV file types.
  • In the NIBP Analyzer, use the Vernier Sensor? control to specify measurements taken from Vernier medical hardware.
  • (LabVIEW SignalExpress) In LabVIEW SignalExpress, you can run SignalExpress example projects that utilize the ECG Feature Extraction and HRV Analysis applications.
Download the new Biomedical Startup Kit 2.1
We also release the full source codes freely for internal purposes only upon request to [Edit: email removed as it is no longer used for support*]
The Biomedical Startup Kit 2.1 Source Code Version include the following features:
  • All the application source codes in LabVIEW.
  • You could  use the Biomedical VIs and Express VIs located on the Functions»User Libraries palette to create biomedical applications in LabVIEW. These VIs and Express VIs enable you to perform the following functions:
    • ECG and EEG simulation
    • File input, such as loading and converting biosignals from various file types
    • ECG preprocessing
    • ECG feature extraction
    • HRV (Heart Rate Variability) analysis
    • EMG RMS, mean power frequency (MNF), and median power frequency (MDF) calculations
    • EEG bispectrum and bicoherence analysis
Palette Views:
EEG Bispectral Analysis:
Thanks!
Zhijun Gu
*For support please use standard customer support channels
Message was edited by: Matt_McLaughlin
Message 1 of 11
(11,272 Views)
Nice with source code available on request. A have asked for that. But I guess this source code need some toolkit. It is perhaps a good idea to inform the community about which tool we need. If we plan to use the source code.
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 2 of 11
(5,368 Views)
You are right. You could see the detailed requirements in the readme if you have received the source code installer.
I attach the requirement here:
  • Windows Vista/XP/2000
  • LabVIEW 8.6 Full or Professional Development System
  • LabVIEW 8.6 Advanced Signal Processing Toolkit
  • LabVIEW 8.6 Digital Filter Design Toolkit
  • LabVIEW Adaptive Filter Toolkit 1.0
  • DAQmx 8.8 (If you want to acquire biosignal.)
Thanks!
Zhijun Gu
Message 3 of 11
(5,368 Views)
I just tried the biomedical startup kit 2.1and found there was an issue with the file converter when I converted an MIT file to a MAT file. I used the example  file 100.hea from installation. It can generate the MAT file but the variable name (100MLII) in MAT file is illegal in MATLAB as it starts with a number. I think the variable name was derived from the 100.hea, which defined the signal as 100MLII.
Wei
Message 4 of 11
(5,368 Views)
Thanks for the feedback! It may be a bug. We will fix it.
Zhijun
Message 5 of 11
(5,368 Views)
One suggestion. It would be helpful if the file converter allows the user to rename the MATLAB variable name. Thanks.
Wei
Message 6 of 11
(5,368 Views)
Hi Wei,
We have fixed the bug in version 2.1.1. Please redownload the installer in the same link I mailed to you.
Thanks!
Message 7 of 11
(5,368 Views)
Hi Zhijun,
Our Institute has Labview 8.2 subscribed. Is there any way to use the Biomedical Startup Kit using Labview 8.2?
Thanks.
KP
Message 8 of 11
(5,368 Views)
i would ask aquestion please
i have now eeg  digital signal  as samples
and i want to get the analog shape can i ?
Message 9 of 11
(5,368 Views)
i need evaluation version of biomedical start up kit.. where can i download this?
Message 10 of 11
(5,368 Views)
