Biomedical User Group Discussions
EEG analysis
My project  is analysis  of EEG signals using Spectral  monitoring .  Normally, the time domain signal is broken into short  epochs.  The  data from the FFT is binned into frequency ranges according to standard  EEG definitions:  Delta, (0-4Hz), Theta (4-8Hz), alpha (8-12Hz) , etc.  The cumulative power is reported.can anyone do me a favor?
(3,972 Views)
It is similar to HRV spectral analysis:
You may refer to HRV Analyzer in Biomedical Startup Kit.
Thanks!
ZJ Gu
(3,282 Views)
