Biomedical User Group Discussions
HELP!!! Implementation of cone-beam reconstruction algorithm with labView...
Is there someone that could help me to implement the feldkamp algorithm (cone-beam) in labView?? because it is object of my thesis and i'm in my early experiences with labView ...thanks a lot!
(4,365 Views)
Your Q suggests that you might have an implementation in another language or IDE. If so, you could call that one from LabVIEW. If not, well, after having had a quick look after a paper describing that algorithm, you must be very lucky to find someone that could and is able and willing to share with you.
Greetigs from Germany!
Uwe
(3,511 Views)
Well, i hope that someone, anywhere in the world, could help me ...otherwise i will try to risolve it in some way...thanks!
(3,511 Views)
