Biomedical User Group Discussions
How to get frequency spectrum from spectrogram?
i'm trying to implement some wavelet frequency analysis in EMGS signal.
i've got a scalogram (X- time, Y- scale, Z-energy) and a spectrogram (X- time, Y-frequency, Z-amplitude), as you can see in the picture (middle graph).
How can I "rotate" axis of the graphic, or extract the frequency spectrum to get (Y-amplitue, X- frequency).
Or yet, how to get the values of X, Y and Z axis into arrays to build a new graphic? I've tried to use some property node, but no success.
Thanks!
Ramon Campos
(5,127 Views)
Hi Ramon,
I think in the block diagram, you could find the data for displaying is just a 2D array. It is easy to right click on the plot to select "transpose".
Thanks!
ZJ Gu
(4,061 Views)
Hi ZJ Gu,
in fact I try to transpose the graph, but it became something strange, as you can see....
and that data don't resolve my question.....
but thank you for the tip.
I'm still trying!!
Ramon Campos
(4,061 Views)
Hello again ZJ Gu!
after a big mess, I got some result.
but when I use low wavelets scales (4, 8, and 16) the spectrogram seems weird.
Can you please take a look at my code?
Here are the VI (lv 2010) and an EMG signal from biceps brachii in a 30 seconds isometric contraction.
Thanks!!!
(4,061 Views)
