Biomedical User Group Discussions
Install Biomedical Toolkit to myRIO RT
I am in the last phase of my senior project and I was shocked to know that the biomedical toolkit is not supported by myRIO RT. When I run a VI that has BMTK blocks I get this error
I tried copying the needed code to the RT target but it caused conflicts and overwhelmed the device with VIs. I want to know if there is any way I can install the biomedical toolkit to myRIO and use it for real-time projects?
(5,135 Views)
Some toolkit VIs don't support on RT like what you use above. Most of those measurement and analysis VIs should work.
Thanks!
(4,457 Views)
