Biomedical User Group Discussions
Question on the RMS Calculation of LabVIEW
Greetings,
I have been using the "Amplitude and Level Measurement" function of LabVIEW to calculate the RMS value of a signal saved in LVM format (sample is attached). I've attached the LabVIEW file that I'm using. Please don't mind the "chaos" in the code. I just need what equation or method the "Amplitude and Level Measurement" function is using to compute for the RMS of the signal. Thank you.
(4,462 Views)
(3,383 Views)
