Biomedical User Group Discussions
Real time ECG acquisition
I am doing a project on real ecg acqusition. We used ad8232 heart monitor to acquire biosignals and connected to an arduino uno.  We then used the labview interface for arduino to process the data and get a normal ECG wave. We were wondering if we can use the biomedical toolkit with the labview interface for arduino without the DAQ box? Any help would be greatly appreciated.
(8,820 Views)
In the toolkit, processing/analyzing is separate from connecting DAQ device. If you could get data correctly, absolutely you could use toolkit VIs to process the data.
Thanks!
(8,135 Views)
Hi, I just saw your  message. Thanks for your help!
My group used the biomedical toolkit with the arduino uno and it worked fine. We are facing some difficulty in finding the pr interval though as the pr interval measured is either wrong or it cannot detect the p wave when we used a ecg stimulator to stimulate a normal ecg signal. Any help would be greatly appreciated. Thank you!
(8,135 Views)
can i look on your block diagram ? are you using lifa or linx?
(7,262 Views)
Hi.. May i look at your block diagram? if u could attach it as a picture here that would be very helpful to me..
(5,736 Views)
