Biomedical User Group Discussions
Tomographic image reconstruction using LabVIEW acquired data
Has anyone here had experience with the inverse radon transformation for  tomographic image reconstruction using LabVIEW acquired data?
Message 1 of 35
(29,861 Views)
We do x-ray and terahertz ct at NASA. The vendor who developed the terahertz ct system uses LabVIEW to acquire the data, and then uses the radon transform from matlab I believe to reconstruct the data from the sinograms which are stored as txt files. I have to look at the ct manual again - I think a matlab script is called directly versus the use of a mathscript node in LabVIEW. I can give you a contact at the vendor if you need more details.
Don
Message 2 of 35
(8,870 Views)
I use the Vision toolkit to perform the inverse radon transform. The attached is saved as LV 8.6
Randall Pursley
Message 3 of 35
(8,870 Views)
Great example!
Do you have any real data for us to play with? Could you save an example dataset to your VI as default value?
Thanks!
ZJ Gu
Message 4 of 35
(8,870 Views)
I am interested in an example as well and also what backprojection filter(s) you applied.
Message 5 of 35
(8,870 Views)
We are in the early stages of research and development.  Currently we are collecting data to which we intend to apply the inverse radon transform using Matlab.  I posted because I am interested in the experience of others.  As to sharing data, this would require NDA's but if you are interested in contributing you can express this by emailing me at sraylab@gmail.com.
Message 6 of 35
(8,870 Views)
I think that both ZJ and I thought that rpursley8 might have example / example data....
Message 7 of 35
(8,870 Views)
Thanks for the clarification.
Message 8 of 35
(8,870 Views)
Here is an example (LV 8.6) that I have a slice of a 3-tube phantom.  The backprojection filters are written in Mathscript so you need that toolkit to execute that part of the code.  I placed that part of the code in a Diagram Disable Structure.  The other frame has a constant that contains a Cosine filter.  I also added a Wait function to the reconstruction loop so you can see the final image as it builds up.
Randall Pursley
Message 9 of 35
(8,870 Views)
Thanks!
This is a great example for showing the tomography reconstruction.
ZJ Gu
Message 10 of 35
(8,870 Views)
