Biomedical User Group Discussions
can any tellme how to use Bandpass filter in cRIO9073 and NI9201 for EMG signal filtering
Hi i am using cRIO9073 and NI 9201 for acquiring EMG signals, i am able to get the Raw signal but i am unable to filter it,even i need to power spectrumand RMS for that,please  tell me the procedure and please post some examples if any,
i am attaching FPGA vi and Host VI screenshot
(4,632 Views)
I think you need to buffer your data point  to an array, then pass along to filter or power spectrum VIs. Those VIs are usually requiring a signal block not a point. You could try to steam your raw signal into a TDMS file and attach here for us to have a look. Verify the VIs using offline data, then move to on-line analysis would be a nice way.
ZJ Gu
(3,486 Views)
i did the bandpass filter but i am unable to run it,when i run the VI cRIO is getting disconnected ,i am attaching the my VI plase heva a look and clarify me how to design
(3,486 Views)
As you data is still point-by-point, you should use the DBL instance from DFD Filtering.vi, then display the point data using Waveform Chart.
Thanks!
ZJ Gu
(3,486 Views)
Sir,
i have changed  filtering technique now, i am able to run it,now please tell me weather my filtering technique and wiring  is correct or not.i am unable to see the filter FFT
i have attached my blockdiagram and filtersettings and graph.
please  help me..........
(3,486 Views)
