08-27-2011 01:40 AM
Thank you very much to help me, I did what you advise me to do but I didn't find them in NI.com
The files are:
Biosignal Import (block by block).vi (I found 4 results for it, but they didn't contains the needed file to download)
Configure Biosignal Import.vi (0 results)
Biosignal_Fileload_Settings.ctl (0 results)
What can I do?
Thanks 🙂
rira
08-27-2011 02:18 AM
Dear Zhijun Gu,
I want to clarify some things: The last times (before your reply of 22/08) I didn't understand that the file named samecode_for_file.vi is the source code for the Biomedical Startup Kit, I thought it's just an example that you give me that way I didn't run it and I need to install Biomedical Startup Kit. I search the one named biomedical_startup_kit.zip and I downlowded it. When I want to run it, it ask to me to before downlowd engine runtime to be able to run biomedical_startup_kit.zip
I have to uninstall some files, or it's ok?
Thanks ![]()
Rira
08-28-2011 10:45 PM
Hi Rira,
biomedical_startup_kit.zip is the executable version. Did you email us to request source code if you want? It is a different installer.
Thanks!
ZJ Gu
09-12-2011 10:45 AM
Hi Zhijun Gu,
Thank you very much for your help, I send an email and I'm still waitting to solve my problem
Best regards!
Rira
