Biomedical User Group Discussions
graph setting color and scale
Im have a problem with this graph. I try to get the graph transparent and fit the x scale to fixed. But each time i re-iniciate the vi, it will be grey and auto scale X. How I can do it fixed ?.
Regards in advance. LV2013 file
Fred.
(4,396 Views)
Hi Fonsi,
This is not standard graph control. It is a customized XControl for easily plotting HRV spectrum. It should be a bug that we don't save some plot properties as internal state for next time's loading.
Sorry for the inconvenience.
You could drop down a Waveform Graph and directly wire the spectrum to it. Then you could change the plot properties.
Thanks!
ZJ
(3,276 Views)
Yes, i see it opening the 'show diagram'. I cant fit the scale X to fixed and change the color, since I need to fit in report... it would be great to fit it.
I will try to use a new waveform graph.
Regards.
(3,276 Views)
