Biomedical User Group Discussions
how to find heart rate from negative peaks?
i am working on a projet of detecting pulses using led and photodiode,i want to get the heart rate in bpm from the pulses.i got a VI from NI website.i am attaching the zip file with this.but the problem i have is,due to change in logic in my hardware i am getting negative peaks for every pulse,if there is no pulse,i am getting a constant voltage of 4 volts,if a pulse is detected i am getting output in around .1 volts.is there a chance of changing the program to suit my requirement,that is give the bpm from negative peaks?i tried changing "peaks" to "valleys" in peak detector VI,but there was no change.
(3,696 Views)
Invert the signal and add 4 to it before passing it through the peak detector.
Randall Pursley
(3,205 Views)
thanks sir,will try that.thanks for you fast response.
(3,205 Views)
