Biomedical User Group Discussions
lf/hf ratio in hrv
can anyone tell me how can i do some analysis on lf/hf ratio using the biomedical startup kit3.0 .
i should be able to know when there is a decrease in lf/hf ratio than a particular value and if it does i want to produce a beep sound.
(5,408 Views)
Do you have LabVIEW (not only Runtime Engine)? It is very easy to place a compare node and beep sound using PC sound card.
Thanks!
ZJ Gu
(4,177 Views)
i have labview, but how can i export data to labview from heart rate variability (HRV) analyzer in the biomedical kit3.0.
also how can i perform the same for real time signal using hrv analyzer
(4,177 Views)
The HRV Analyzer could export a report (txt). You could load the txt which contains the LF/HF value in LabVIEW using read from text file VI.
ZJ Gu
(4,177 Views)
