Biomedical User Group Discussions
new guy for biomed startup kit
hi, everbody. I'm a newcomer to biomed startup kit and confront some problems. After i installed labview 8.6, run-time engine and biomed startup kit, i cannot find functions in the palette of labview but find execuable applications in the installation directory of biomed startup kit. But what i need is some addons in the palette of labview for my programming. what mistakes did I take? do I need to install the source code version of the kit? if yes, where can I get one? thanks.
(4,213 Views)
Startup Kit is obsolete. Please download the new Biomedical Toolkit which requires LabVIEW 2012/2013.
(3,456 Views)
Hi, ZJ. Thank you very much. Really! it took my 2 days! you mean I first install LabView 2012 and then Biomedical Toolkit? does the Toolkit require other kits? it seems Biomedical Toolkit is not free, so does this mean I can only use the evaluation version?
Best Wishes
DM
(3,456 Views)
The executable part of the toolkit is still free. The VI library part could be used for 45 days of evaluation mode.
Thanks!
(3,456 Views)
