BreakPoint
4-wire (Kelvin) resistance measurement
Wow that is really playing tricks with my mind. There are a total of four wires, two red ones and two black ones between the heatshrink?
LabVIEW 2012
Message 11 of 20
(7,478 Views)
If you want to understand what is going on, here is a simple picture.  The current leads generate a voltage between two points on the sample, and the voltage leads measure the potential between the two contact points.  In a good conductor, the current flow in the sample is predominantly along the line between the two current lead contact points.  Away from that line, little current flows and the potential is nearly constant.
Ideal:  You measure the potential difference between the two contact points of the current leads, largest possible potential difference, highest inferred resistance.
Clips Closed:  Close to ideal, measuring most of the potential drop.
Clips Open:  Now you measure a much smaller potential difference, this would lead you to infer a smaller resistance.
@Steve:  I would ignore the picture completely, it is a distraction.  A picture of the "actual" leads would probably be taken on top of a cluttered benchtop, this is a stock photo.  Even a two-wire measurement would show the same effect (it would just be tricky to account for the lead resistance).
Message 12 of 20
(7,476 Views)
Ah. I thought it was the actual leads. I was kind of wondering how he got it to have a completely white background like that. Smiley Happy
LabVIEW 2012
Message 13 of 20
(7,471 Views)
Of course now it sounds like a stock photo of the actual leads....  Anyway, it is clearly a four-wire measurement.
Message 14 of 20
(7,466 Views)
There's an explanation HERE.
Shane.
Message 15 of 20
(7,442 Views)
Bingo!
Jim
Message 16 of 20
(7,429 Views)
If I hadn't put this in BreakPoint I could have marked this as the solution.  It makes sense, anyway, as it matches my observations.
Thank you.
Jim
Message 17 of 20
(7,401 Views)
Request the moderator move this thread to the LV forum.
It will get more exposre, you can mark solution and it will show up in a search (cough cough hack hack) of that forum.
And if the situation is still the same as in the past, it will show-up on the various "mirror sites" and therefore help more people.
Ben
Message 18 of 20
(7,392 Views)
Actually we have been flogging a few students for posting non-LV engineering problems on the LV board so his feels like a good home. I could see the utility of a new board for technical problems to tap the collective knowledge without being buried in jokes or trespassing on other boards.
Message 19 of 20
(7,371 Views)
Excellent idea! You should post that to the feedback forum.
LabVIEW 2012
Message 20 of 20
(7,365 Views)
