BreakPoint
Am I way off here?
I want to use this thread as a place to ask some questions where I'm not sure if they make sense or not.  Some of them might be possible Ideas for the idea exchange but sometimes I'm so caught up in my own way of thinking that I don't see the stupid ideas for what they are.
Input desired.
Message 1 of 12
(9,348 Views)
I have often wished there was some easy way to have a method to add custom graphics or effects to a FP.  Having recently done some coding with the "Back" "Middle" and "Front" images for an XY graph control I wondered if similar functionality for a FP would be of interest?
I've long yearned for a kind of drawing canvas for the entire FP, but it doesn't currently exist.
Message 2 of 12
(9,347 Views)
You can ofcourse drag a picture directly to the FP, but if you want it interchangable/configurable you'll need to place a big picture control. However, the idea of being able to link a picture as FP-background-property as an option instead of a solid color is quite nice. Also a color toning ...
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 3 of 12
(9,342 Views)
/Y
Right click the horizontal slider of a Front Panel and select Properties. From there you can select a picture image as a background, set to either stretch, centre or tile.
Thoric (CLA, CLED, CTD and LabVIEW Champion)
Message 4 of 12
(9,330 Views)
I very much wish for more enhanced/advanced methods for handling graphics in LabVIEW front panels. The currently available set of features are quite minimal when compared to other languages capable of creating GUIs.
Message 5 of 12
(9,329 Views)
So do you guys reckon it's worth an idea?
I mean, I already made one WWAAYY back, but that doesn't seem to be doing too well.....
Shane.
Message 6 of 12
(9,324 Views)
I personally don't understand either the original idea or what's suggested here.
___________________
Try to take over the world!
Message 7 of 12
(9,315 Views)
Read you IE post, not sure I absolutely get what you are asking for. Are you suggesting you want to be able to draw an image on the front panel, that may or may not be full panel sized, that kills any user clicks than are sent to it, that can be programmatically shown/hidden/changed? Does the picture control not do all this for you anyway? The image can be programmatically changed, it can be set to Disabled so that it cannot be interacted with, it can be made visible/invisible, and it would sit above any controls on the front panel making them inaccessible. All programmatically. Did I miss something?
Message 8 of 12
(9,314 Views)
Thanks, haven't noticed that. 😄 And with that information i could easily find the property node for inserting an image. 🙂
/Y
Qestit Systems
Message 9 of 12
(9,311 Views)
Also, I think the discussion here shows quite clearly that a single thread won't work for more than one idea.
___________________
Message 10 of 12
(9,308 Views)
