BreakPoint
Challenge for the experts !
Since there are few contributions to this thread, I'll give the solution to the original question : the answer is 0x01000037.
This is simply the hex code for the chameleon color (d16777271, although it appears as R0:G0:B0 in the LabVIEW color picker).
It makes a front panel or diagram object adopt the background color (and not the color of the underlying FP object).
I found the idea on the LabVIEW wiki (although there was originaly a confusion with transparency...). The use of the system label was suggested to create labels for the diagram wires as a form of code commenting. Of course you can also use it to dig holes through FP or diagram objects !..
 The creation of round holes is a bit more complicated... 😉
Message Edité par chilly charly le 01-04-2009 09:46 PM
Chilly Charly    (aka CC)
Message 11 of 23
(9,209 Views)
Ah, that's good to know.
(Now, how would you punch a hole all the way to the computer desktop? 🐵
We can possibly get some clues by looking at the hierarchy in tst's solution. Can we?
Message 12 of 23
(9,203 Views)
While I did know about the system label color, I have to admit I didn't think about it, maybe because I already had code which needed only a couple of minutes of modification to do your first example. There are also problems with the system label color (e.g. it only works on the background image and it doesn't work inside tab controls).
As I mentioned, those who know what they're doing can get some details from my example. Also, I decided to choose a password which would be simple, so the first to figure it out is welcome to post an image of part of the BD.
___________________
Try to take over the world!
Message 13 of 23
(9,192 Views)
Like this,
but it doesn't satisfy CC's requirement, as it uses the Windows API.
___________________
Message 14 of 23
(9,191 Views)
I downloaded this several years ago and have never been able to play with it.  I checked it out before posting and the USA example only worked if I put the full path to the bmp.  Primetest wrote this code and posted it to a LTR challenge.  It used to be a toolkit they sold until the challenge.  I am assuming it uses several of the WinAPI functions tst is referring to.  Theie examples do not put a hole in the middle of the front panel, but make the panel non-rectangular (very prominent in media players and such).
Message Edited by Matthew Kelton on 01-05-2009 05:34 AM
Message 15 of 23
(9,187 Views)
I was actually thinking of using these functions, but didn't feel like working out exactly how to create the right shape, so I went down another (actually simpler, and one which I probably should have thought of first) path.
___________________
Message 16 of 23
(9,167 Views)
Here's tst's BD for the beef of his code.
Message Edited by Matthew Kelton on 01-05-2009 09:10 AM
Message 17 of 23
(9,152 Views)
Since you've gone and exposed the important bits, you might as well post the password as well.
P.S. This was quick code written from scratch, since I didn't have anything which would have done the round hole. That's why it's not documented and not particularly clean. It's quite possible that there are more efficient ways of doing this.
___________________
Message 18 of 23
(9,139 Views)
Well, you said it was "simple".
Message 19 of 23
(9,132 Views)
For those wondering, the Windows API function used to cut a hole in the window can be seen here. One of its parameters is a color input (I believe in that example that color is a constant) and when you use a color and make the panel opaque, everything of that color in the window becomes completely transparent. You can even click through it to whatever's below the window.
You should note that the VI posted there was just a quick example. It needs work and cleaning up.
___________________
Message 20 of 23
(8,462 Views)
