BreakPoint
Code Capture Tool
@TonP wrote:
if someone can back save to 6.1 (tst?)
Yes, if things are supported there.
I'm interested in how you're planning on doing the different versions. I noticed that VIPM let's you choose between different versions of the same package, but how are you planning on doing the version numbering?
___________________
Try to take over the world!
Message 11 of 18
(9,190 Views)
Here's an OGP that install a different enum for different LabVIEW version:
For version 6.1 and up the enum will only have a value of 6.1 for 8.2.1 and up it wil have a value of 6.1 and 8.2.1
The same can be done for operating systems.
Added as .zip so you can look at it and see what happens. Just rename to .ogp to install
Ton
My LabVIEW Ideas
Message 12 of 18
(9,172 Views)
OK, I think I understand - you can control what happens with each file inside the installation depending on your LV version. That's really nice. It would have been nice if we could also define a mass compile step at the end of the installation.
BTW, there is a problem with your example (I understand it's just a quick one). File Group 1 is exclusive to 6.1 so 7.0 to 8.2 don't get the enum extracted. I assume it is possible to include both a larger than and a smaller than condition for the same files.
___________________
Message 13 of 18
(9,171 Views)
Hi Tst,
you're correct the possibilities are endless (sort of)....
Could you upload a 6.1 version?
Ton
My LabVIEW Ideas
Message 14 of 18
(9,121 Views)
Tomorrow, yes, but don't you want to fix it first?
I would still vote for getting rid of the timeout and the keys for cycling (unless I hear any objections).
P.S. are you planning on attempting to clean up the mess inside the VI which creates the images?
___________________
Message 15 of 18
(9,117 Views)
I have fixed it by debugging some things.
What is the problem with the timeout? It can be usefull for incapsulating the tool inside another VI (for documentation purposes), the cycle keys are just a nice gimmick.
I think I'll try to clean up the VIs since this will be a major hobby-during-the-summer project.
Ton
My LabVIEW Ideas
Message 16 of 18
(9,113 Views)
How about we move it to email?
You should have my address from Info LabVIEW.
___________________
Message 17 of 18
(9,109 Views)
The tool has been finished after weeks of hard labour, long emails and numerous commits to SF.
Finished by yours truly and Yen/tst the tool is released to LAVA
Have fun and add it to your Tools menu!
Ton
My LabVIEW Ideas
Message 18 of 18
(8,766 Views)
