BreakPoint
Error handling in the LAVA UI Tools addin
I had no idea where else to post this, but it amused me.  Found in the "Dialog Box__lava_lib_ui_tools.vi" from the LAVA addin. Thought I'd share.  The "No Error" is an event driven state machine.
(6,559 Views)
Uh...is it me or is this flawed?  If you pass in an error on the error in, it goes to the error case, and keeps the error, loops back around, and goes to the error case...forever.  It doesn't matter if you put the Exit on the string shift register the first case statement evaluates the error case first.
Here is the support page on the LAVA UI Tools that I think you are talking about.
https://lavag.org/topic/11045-lvtn-ui-tools/
(6,536 Views)
Perhaps you are flawed.. Not enough information.  The vi is flawed as you pointed out.
(6,514 Views)
That was the amusing part!  Pass an error in and get an infinite loop...
(6,478 Views)
