BreakPoint
Incongruous sightings of LabVIEW/NI
Yes, Semilab, since 2018. That was the year when I left LabVIEW programming, and turned to the dark side, C#/.NET 😄
Well, actually I do not develop directly the end product, I mainly do SW dev project management nowadays. I develop with C#, but mainly internally used calibration/DAQ applications.
We have lots of metrology developments and manufacturing for semi/display/photovoltaic industry (mainly large robotized automated inline machines), but the AFM section is a relatively new thing here. So very exciting time here, to work in this field now, lots of challenges! 🙂
Message 101 of 197
(5,578 Views)
LabVIEW apparently helped image at least one black hole, but probably two (both so far).
https://www.youtube.com/watch?v=Q1bSDnuIPbo&t=520s
Certified LabVIEW Architect
Message 102 of 197
(5,512 Views)
Just curious, how do you know this was done in LabVIEW?
Message 103 of 197
(5,453 Views)
I actually don't know, but the panels to the left sure looks like it.
Message 104 of 197
(5,415 Views)
The panels with the graphs to the left are very blurry and could be anything.
The ones on the right could be made in LV, but I would say it's unlikely, mainly because they have vertically centered numbers, which can be done in a number of ways, but would require some actual work.
___________________
Try to take over the world!
Message 105 of 197
(5,392 Views)
I could of course be wrong, but I see some typical LabVIEW features:
Up in the left corner, the graph has rounded vertical sides of the same apparent width as the default XY graph. The rounding-effect and width of it  matches LabVIEW. I don't think anyone would do that intentionally to a graph in another language. Look at the right side:
The panel in the lower middle has scale marker layout of default LV-style, with a centered scale label and grey background (a bit hard to see in a single frame here though):
Of course this could be any other language but this is the default style in LabVIEW, apart from the background color of the plot area. Graphs I see created in other languages seem to have the same background color for the scales as in the plot area (white).
I first thought I saw LabVIEW-grey as FB BG, but it could be another grey.
The left grey panels were the only ones that looked like LabVIEW to me.
Message 106 of 197
(5,389 Views)
Really?
Any LabVIEW programming requires actual work. No matter how much fun it is 😄
Message 107 of 197
(5,374 Views)
@altenbach wrote:
Really?
Right, the total amount of work is greater than zero, therefore "some work".
My pedantic old grumpy self is perfectly satisfied that there's no contradiction here.
Message 108 of 197
(5,368 Views)
Message 109 of 197
(5,352 Views)
Sorry to add to the pedantry, but tst said "vertically centered". It takes some creativity to get a numeric indicator vertically centered on a much taller background. It could be done with the transparent indicator on top of a decoration.
Message 110 of 197
(5,340 Views)
