BreakPoint
Interesting Stuff
In this thread,
http://forums.ni.com/ni/board/message?board.id=170&message.id=126822&jump=true
Rolf shares a tidbit to let you implement property nodes such that you minimize the impact on the UI.
Ben
Message 11 of 128
(18,299 Views)
I knew it was possible to play with a numeric control's digital display to get an extra control, but Altenbach has posted a cool example of how to do this repeatedly to get several controls in one control. Can anyone think of anything similar in any other control?
___________________
Try to take over the world!
Message 12 of 128
(18,274 Views)
Have a look at this thread. It brings up an option of calling a DLL to use the graphics card to accelerate sorting operations.
___________________
Message 13 of 128
(18,226 Views)
The LV developers are going to discuss LV with the public. I have posted a suggestion to float the thread, but in case it's not done, it can be found here.
___________________
Message 14 of 128
(18,210 Views)
Using Windows XPs remote desktop feature to use/debug software located on a totally different computer does NOT require a license for LV on the second PC (the one running LV remotely). This has been confirmed as not violating the normal LV license.
Shane.
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
Message 15 of 128
(18,154 Views)
In this thread
http://forums.ni.com/ni/board/message?board.id=170&message.id=130492
Mike Porter introduces a novel (to me anyway) way of handling multiple error threads. Not only does it enhance error reporting>>>Tracking>>>troubleshooting, but it also harnesses just about every feature of the error cluster you could think of.
Ben
Message 16 of 128
(18,125 Views)
In this thread, Shane and Philip had a long discussion about what the run-time engine does with a VI. I believe I understood this correctly before reading that thread, but it seems that this isn't documented well enough, so here's a chance.
___________________
Message 17 of 128
(18,107 Views)
In here, Ben shows another example of control customization by replacing part of the control.
___________________
Message 18 of 128
(18,097 Views)
Here shows how you can scale your numeric display using units e.g. units of cm/m scales the value by 100 and the control remain unitless.
LabVIEW, C'est LabVIEW
Message 19 of 128
(18,065 Views)
Some interesting control customizing.
___________________
Message 20 of 128
(18,035 Views)
