BreakPoint
LabTOONS, The secret life of LabVIEW objects!
Hi Christian,
I like your LabTOONs. I have two I like most the "Scary campfire stories." 5-26-2008 and the "pinch of LabVIEW trivia." 5-30-2008.
The link to Verzion Commercial is a little bit buggy.
Also as European from the description I can guess how the story goes in the advertisment so I can understand your LabTOON.
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
Message 51 of 230
(18,556 Views)
We get them in Canada also.  And how true... You're cartoon is very true.  Excellent.
Message 52 of 230
(18,554 Views)
waldemar.hersacher wrote: The link to Verzion Commercial is a little bit buggy.
Yes, apparently it is corrupted, correct is: Verizon commercial
Sorry, I'll try to have the moderator correct it. Usually, I enter links manually in HTML mode. This time I used the link button. Apparently I did not follow correct procedure. 😞 It seems if you omit the "http" part, the forum software modifies the link and makes it relative to NI)
I actually recently became a Verizon customer and I was the first one in my area on FIOS. (I was able to sign up before they even started advertising, right after they finished wiring the neighborhood.)
Their FIOS commercial with Michael Bay is pretty good. Still, to improve the commercials for fiber optic to the home, Verizon could take some clues from a Hong Kong provider. See Video. 😄
Message 53 of 230
(18,464 Views)
Getting lost on a gigantic diagram...
Message Edited by altenbach on 06-01-2008 12:48 AM
Message 54 of 230
(18,439 Views)
Additional to GPS we need a route planner to find the shortest way from source to sink.
Waldemar
Message 55 of 230
(18,430 Views)
A quick trip down memory lane, all the way to LabVIEW 1.2 and the year 1998.
Message Edited by altenbach on 06-02-2008 01:16 AM
Message 56 of 230
(18,394 Views)
Of course the quote was from the movie "Back to the Future", which set at Unversal Studios burned down over the weekend in a big fire.
  • "Back to the Future" set: The town square, including the courthouse area and the clock tower that plays a central role in the film.
Message 57 of 230
(18,358 Views)
Altenbach:
Where did you get that Labview 1 block digram?  Black and white.  Wires break if you move an object.  Pretty ancient.
- tbob
Inventor of the WORM Global
Message 58 of 230
(18,341 Views)
It's from the LabVIEW 1.2 manual of 1989, available online. Above the panel is a link to the PDF (huge file because it's all scanned in). 😄
Message 59 of 230
(18,336 Views)
ARGH! Sequence structures!
Message 60 of 230
(18,318 Views)
