BreakPoint
LabVIEW programming aids
@Darren wrote:
Y'all should use Traverse for GObjects.vi instead of AllObjs[] if you want to nail Stacked Sequences on nested diagrams too.
Here.  Happy?
Message 11 of 12
(2,995 Views)
@crossrulz wrote:
You know, I started making a version that does that, and it turns out that TRef Traverse.vi has a Stacked Sequence Structure in it!  Bad Darren!  Granted, it is a single frame just to perform a Class Operator.Remove regardless of an upstream error.  But still.  Maybe NI should change it to a Flat Sequence Structure...
I don't have a problem with single-frame Stacked Sequence Structures. Especially those found in VIs written with LabVIEW 6.1, before the Flat Sequence Structure existed. 😉
Message 12 of 12
(2,971 Views)
