BreakPoint
Monthly Bug Thread Feb 2007
This is the continuation of the January 2007 Bugs Thread.
  1. Each post here should only contain a brief description of a bug, together with a link to the thread where it is being discussed.
  2. One post/bug!
  3. One bug/post!
  4. No discussion of bugs. All discussions of a bug must take place in the original linked thread.
Message 1 of 16
(11,818 Views)
Jeff T report in this thread
that R&D are working this issue under CAR #3S8CKMG8
Ben
Message 2 of 16
(11,812 Views)
In this thread,
the execution highlighting does not work properly. The SDE for the sub-VI will show transitions even though the sub-VI is NOT being called.
Confirmed with NI Support on SR# 923127
Car ID: 36HGD0PU
Thank you,
Ben
Message 3 of 16
(11,803 Views)
See this thread
No CAR posted at this time.
Ben
Message 4 of 16
(11,789 Views)
Setting the format precision of an graph axis via a property node fails if formatting is set to "automatic" and input is a waveform.
The error popup says that the values must be between 0 and 8, which it already is.
Works fine if:
  1. datatype is an array instead of a waveform
  2. format is anything but "automatic". (floating point, scientific, absolute/relative time, etc. all are OK with this property).
http://forums.ni.com/ni/board/message?board.id=170&message.id=227619&jump=true
Message 5 of 16
(11,781 Views)
In this thread
Chetan confirms the bug.
Ben
Message 6 of 16
(11,776 Views)
resizing a gauge programmatically messes up the proper proportions between decorations and gauge scale.
Message 7 of 16
(11,755 Views)
in this thread
http://forums.ni.com/ni/board/message?board.id=170&message.id=228685&jump=true
a user reports the scroll bars appear to be disabled when setting the tab order of a cluster.
Ben
Message 8 of 16
(11,719 Views)
Message 9 of 16
(11,714 Views)
More details are available on his LAVA post
PJM
vipm.io | jki.net
Message 10 of 16
(11,653 Views)
