BreakPoint
Monthly Bugs, April 2007
This is the continuation of the March bug Thread
  1. Each post here should only contain a brief description of a bug, together with a link to the thread where it is being discussed.
  2. One post/bug!
  3. One bug/post!
  4. No discussion of bugs. All discussions of a bug must take place in the original linked thread.
(7,569 Views)
In this thread, jpeters confirms that there is a bug in 7.1.1 (fixed in at least 8.2 - not sure about 8.0), which prevents the "Ignore Errors inside Node" switch from working properly, at least for the VI properties in question.
Jaegen
(7,544 Views)
In this thread
It was reported by Guy04
"For example, if compare aggregates mode is selected in using the "In Range and Coerce.vi" with the inputs (upperLimit, lowerLimit, and x value)  being an array of integers, then compare aggregates does not return correct results.  I've also noticed this with the greater than and less than comparison vi's"
This was reported to R&D (CAR #483H78HR) for further investigation per David L.
(7,528 Views)
Intermittently wrong results when converting a number to a fractional string.
http://forums.ni.com/ni/board/message?board.id=170&message.id=244307
___________________
Try to take over the world!
(7,450 Views)
the time has come to close this thread. let's all continue in the May version of it.
(7,409 Views)
