BreakPoint
Monthly Bugs, August 2013
Continued from the July 2013 bugs thread
August is a big month!
The release of LabVIEW 2013 is imminent! ... but first, many of us will meet in Austin at NI-Week. See you all there!
 The posting rules are as always:
  • Each post here should only contain a brief description of a bug, together with a link to the thread where it is being discussed.
  • One post/bug!
  • One bug/post!
  • No discussion of bugs. All discussions of a bug must take place in the original linked thread.
Message 1 of 9
(11,514 Views)
The text in the downsteam column of a pdf may be mangled by the second column text when generating PDFs from Requirements Gateway in 2013 with some ADOBE installations.  CAR not assigned,  Duplicated by NI.  AEs investigating. (Good NI Week Session though despite that small formatting bug)
Message 2 of 9
(11,448 Views)
Device driver dcd_Aug_13_2.exe (2,266,732,768 bytes) can't be successfully extracted!
Downloaded several times. The same error message displayed.
Message 3 of 9
(11,417 Views)
Make sure to post this bug report in one of the regular forums, then only post a link to it here in the bug thread. (See first post). Thanks!
Message 4 of 9
(11,405 Views)
In LabVIEW 2013, when linking a label to LabVIEW Object, the center of the object is calculated from the center including the label.
CAR 422905 (is LAVA links okay the rules don't specify)
Message 5 of 9
(11,308 Views)
CAR 422018
Cleanup of block diagram can cause comments connected to code to place the arrow on top of the comment.
Message 6 of 9
(11,303 Views)
Message 7 of 9
(11,254 Views)
Bugged tab order in MAX
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 8 of 9
(11,183 Views)
Moving forward, September has arrived and new bugs should be posted in the new thread.
This thread is now closed.
Message 9 of 9
(11,129 Views)
