BreakPoint
Monthly Bugs, August 2015
Continued from the July 2015 bug thread
 The posting rules are as always:
  • Each post here should only contain a brief description of a bug, together with a link to the thread where it is being discussed.
  • One post/bug!
  • One bug/post!
  • No discussion of bugs. All discussions of a bug must take place in the original linked thread.
(8,529 Views)
CAR #540680, "Key Focus is Lost if a Front Panel Object Begins Blinking"
http://forums.ni.com/t5/LabVIEW/Object-loses-focus-because-of-the-property-blink-in-labview-14/m-p/3...
Because we needed more reasons not to use the Blinking property.
(8,276 Views)
Compact RIO ( cRIO )/ LabVIEW Event Handling Bug
If Value Signaled is set, the value changed event is triggered two times. Only happens in cRIO.
Discussed here:
http://forums.ni.com/t5/LabVIEW/Compact-RIO-cRIO-LabVIEW-Event-Handling-Bug/td-p/3184339
(8,120 Views)
Before posting something into the bug thread, be sure what you are posting is confirmed, or at least generally agreed upon to be a bug.  You posted into this thread only minutes after you posted your original message.  Let the original thread have time to be read and a chance for people to try and confirm your bug.
Once you've had a couple people agree you have a bug, or even better, an NI employee agrees and has given it  a CAR#, then go ahead and post in this thread.
(8,110 Views)
August is over and this thread is now closed.
Reporting continues in the September 2015 bug thread.
(8,044 Views)
