BreakPoint
Monthly Bugs, August- December 2019
Continued from the July 2019 bug thread
NEW: The monthly bug threads have been pretty short in the recent past, so let's try to span a few months instead to avoid fragmentation. We will start a new thread in 2020.
The posting rules are as always:
  • Each post here should only contain a brief description of a bug, together with a link to the thread where it is being discussed.
  • One post/bug!
  • One bug/post!
  • No discussion of bugs. All discussions of a bug must take place in the original linked thread.
Message 1 of 12
(12,601 Views)
The Mathscript "rat" function fails for a significant number of innocent inputs. (details)
Message 2 of 12
(12,479 Views)
The scan from string behaves differently in a diagram disable structure by not recognizing the data types from a diagram constant outside of the structure.
CAR #744124
Message 3 of 12
(12,459 Views)
Full discussion
Apparently, LabVIEW 2019 moved the expression node to the scripts palette, with the collateral damage that it is no longer accessible in LabVIEW Base.
(...even though the help still states that is should be available in base while script& formula palette is only available in full).
Message 4 of 12
(12,351 Views)
See https://forums.ni.com/t5/LabVIEW/Peak-find-trouble-doesn-t-scale/m-p/3970006
The number of the filed Bug Report is 351083.
However you need internal access to enter the site and watch the ticket.
Greetings from Germany
Henrik
LV since v3.1
Message 5 of 12
(12,248 Views)
A LV2019 bug breaks the built xy graph express VI. (details)
Message 6 of 12
(12,193 Views)
Loading channel wires generates broken code: CAR 738559
Certified LabVIEW Architect
Message 7 of 12
(12,162 Views)
3D quiver plot has wrong image in help. (details)
Message 8 of 12
(12,132 Views)
Some CDF functions seem to have some wires crossed. (details)
Message 9 of 12
(12,087 Views)
Please don't uncross the wires, just change the documentation.  Otherwise codes that work correctly now will stop working.
Message 10 of 12
(12,079 Views)
