BreakPoint
Monthly Bugs, December 2011
Continued from the November 2011 bugs thread
 The posting rules are as always:
  • Each post here should only contain a brief description of a bug, together with a link to the thread where it is being discussed.
  • One post/bug!
  • One bug/post!
  • No discussion of bugs. All discussions of a bug must take place in the original linked thread.
(9,276 Views)
Not worth a post, not much to discuss. R&D can you edit the post with a CAR when you get it logged?
(9,243 Views)
LabVIEW 2011 (32-bit)
Programmatically changing the panel transparency value alters the value set in the Property Window (not expected or desired), but doesn't set the "dirty bit"
See this discussion.
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
(9,192 Views)
seen here
NI488.2 ver 3.0
(9,145 Views)
Saw this today- very odd no discussion really needed is there?
LabVIEW 2011.0 32 bit on Win 7 64
(9,134 Views)
Why not? There are no repro steps, others might not be able to replicate it, etc. For good order, it's beneficial to have separate threads.
I'm assuming this happens because you show buffer allocations (both are overlayed over the terminal and they're drawn at the same point, so it's not a huge leap), but I haven't even tried it.
___________________
Try to take over the world!
(9,125 Views)
OK, the year is basically over!
After we all have succesfully recovered from the NYE celebrations, let's continue in the January 2012 bug thread.
This thread is now closed.
(9,099 Views)
