BreakPoint
Monthly Bugs, January 2009
With LabVIEW 8.6 a method was made public to allow an object to be highlighted.  This works in runtime mode, however the documentation states it only works in edit mode.
CAR# 142918
Message 11 of 24
(7,744 Views)
Open/Close All Items have disappeared from the shortcut runtime menu of a tree control when the application is built
CAR: 142872
Message 12 of 24
(7,732 Views)
When using stacked plots with wfm chart and in the event case structure 'Shortcut menu activation' I cannot independently change the autoscale settings of the Y axis.
(Details)
Message 13 of 24
(7,715 Views)
In LV 8.6, when a VI is embedded into a subpanel on another VI, when you right-click on the panel of the embedded VI and select "Open Block Diagram", nothing happens.
Corrective Action Request (CAR) number is 124113
Message 14 of 24
(7,690 Views)
Performing a "find and replace" on a block diagram and choosing a boolean constant from the Boolean Palette set by default to "True" results in an error "Merge VIs not found" whereas choosing a Boolean constant set by default to "False" works fine (For both true and false constants.
Confirmed bug, known to NI since last June but they won't give me a CAR... Smiley Mad
Shane.
Message Edited by Intaris on 01-29-2009 11:25 PM
Message 15 of 24
(7,682 Views)
Shane, you should probably start another thread for this.
Incidentally, this is probably the same for any merge VI, not just for the true constant. As a side point, I assume that NI created it as a merge VI because it was easier than writing the code necessary to drop a boolean which doesn't have its default value.
___________________
Try to take over the world!
Message 16 of 24
(7,674 Views)
Tst,
why a seperate thread?  I've already been in touch with NI on this, and it's definitely a Bug.
Can I stay if I get a CAR#?  :smileytongue:
Shane.
Message 17 of 24
(7,669 Views)
For the same reason you don't put all your data in a single database table - order. That's why we came up with the rules which probably appear in the first post of this thread.
___________________
Message 18 of 24
(7,665 Views)
Each post here should only contain a brief description of a bug, together with a link to the thread where it is being discussed.
  1. One post/bug!
  2. One bug/post!
  3. No discussion of bugs. All discussions of a bug must take place in the original linked thread.
Understood.
At which point our discussing the bug is actually against the rules.....  :smileysurprised:
Shane.
Message 19 of 24
(7,657 Views)
February has arrived, so this thread is now closed. Let's continue in the brand new February 2009 bugs thread.
Message Edited by mathan on 02-03-2009 10:40 PM
Message 20 of 24
(7,601 Views)
