BreakPoint
Monthly Bugs, July 2011
Continued from the June 2011 bugs thread
 The posting rules are as always:
  • Each post here should only contain a brief description of a bug, together with a link to the thread where it is being discussed.
  • One post/bug!
  • One bug/post!
  • No discussion of bugs. All discussions of a bug must take place in the original linked thread.
Message 1 of 8
(14,587 Views)
As discussed here, using the function "intrz" in an expression node that operates on an array will cause a compile error.
CAR ID 307846
Message 2 of 8
(14,559 Views)
LabVIEW locks unrelated files if you drag them over a LabVIEW window:
http://forums.ni.com/t5/LabVIEW/LabVIEW-locks-unrelated-files-if-you-drag-them-over-a-LabVIEW/m-p/16...
___________________
Try to take over the world!
Message 3 of 8
(14,533 Views)
Not directly a LabVIEW bug, but the download link for Mathscript for the Mac/Linux uses a downloader that is an exe, and thus requires windows. This seems wrong. There should be a direct download link to the iso file instead.
(details)
Message 4 of 8
(14,507 Views)
The array selection start and selection size property nodes cause LabVIEW 2010 64-bit to crash.  As seen here: LabVIEW 2010 64-bit property node http://forums.ni.com/t5/LabVIEW/Labview-2010-64-bit-property-node-setting/td-p/1636452.
No workaround is available.
The CAR id for this issue is 292599.
Sandra Wells
Message 5 of 8
(14,472 Views)
Latch action booleans inside clusters don't reset when read under a very specific set of circumstances.
(details)
Message 6 of 8
(14,462 Views)
A particular VI with boolean logic caused LabVIEW to crash.
CAR#309566
Message 7 of 8
(14,426 Views)
This thread is now closed.
After upgrading to LabVIEW 2011 (optional), let's continue in the August 2011 bug thread.
Message 8 of 8
(14,385 Views)
