BreakPoint
Monthly Bugs, June 2015
Continued from the May 2015 bug thread
 The posting rules are as always:
  • Each post here should only contain a brief description of a bug, together with a link to the thread where it is being discussed.
  • One post/bug!
  • One bug/post!
  • No discussion of bugs. All discussions of a bug must take place in the original linked thread.
Message 1 of 9
(13,084 Views)
Message 2 of 9
(12,975 Views)
Problem
Array Max & Min returns incorrect Min under specific circumstances (LV2014 SP1 f1)
Steps to Reproduce
The Array Max & Min function returns the Minimum value at the Max output terminal under
specific circumstances: When the Min Index(es) output IS wired and Min Value IS
NOT wired. Attached VI illustrates the problem.
http://forums.ni.com/t5/LabVIEW/array-max-min-bug-LV-2014-SP1-f1/td-p/3155986
Message 3 of 9
(12,924 Views)
http://forums.ni.com/t5/NI-TestStand/Sequence-File-Converter-Help/td-p/3156905
Thanks & Regards
Varaprasath M
Certified LabVIEW Architect
Certified TestStand Architect
Message 4 of 9
(12,870 Views)
Message 5 of 9
(12,843 Views)
Double click a probe in a clone VI takes you to the wrong clone VI - http://forums.ni.com/t5/LabVIEW/double-clicking-on-a-probe-on-a-clone-should-bring-you-to-THAT/m-p/3...
___________________
Try to take over the world!
Message 6 of 9
(12,797 Views)
CAR #534812 " 'Create from Data Type' Method Crashes LabVIEW if Data Type is a Type Definition"
http://forums.ni.com/t5/LabVIEW/Scripting-Crash-quot-Create-from-Data-Type-quot-on-Typedef-Enum/m-p/...
Message 7 of 9
(12,753 Views)
Comparing references of clone of the same reentrant VI returns true, when it should probably return false - http://forums.ni.com/t5/LabVIEW/Explain-THIS-I-dare-you/m-p/3158840#M910854
___________________
Message 8 of 9
(12,706 Views)
June has arrived, so let's continue here.
This thread is now closed!
Message 9 of 9
(12,676 Views)
