BreakPoint
Monthly Bugs, March 2013
Continued from the February 2013 bugs thread
 The posting rules are as always:
  • Each post here should only contain a brief description of a bug, together with a link to the thread where it is being discussed.
  • One post/bug!
  • One bug/post!
  • No discussion of bugs. All discussions of a bug must take place in the original linked thread.
Message 1 of 9
(11,073 Views)
Entering Inf for a numeric constant or control formatted for Relative Time cause LV to crash.
CAR 375872
Message 2 of 9
(11,039 Views)
If an empty array that is disabled&grayed lives inside an array of clusters, it is no longer grayed out (bug!). Once the array is non-empty, it is again greyed out as exepcted.
Details
Message 3 of 9
(10,996 Views)
Thanks will wait for car to be answered
Message 4 of 9
(10,982 Views)
Discussed here
Message 5 of 9
(10,964 Views)
Hi Tsb/Altenbach,
Thanks for bringing this to our attention. This was reported to R&D (#396090) for further investigation. As mentioned earlier, a possible workaround would be to initialize the array with zeroes. Thanks for the feedback!
Doug W
Message 6 of 9
(10,938 Views)
When flattening and saving a class to a file that contains a DAQmx Device in its private data the device is written to the file. But when unflatting from the XML, the device is blank. Seen here with code example. CAR with R&D under ID 398196
Message 8 of 9
(10,813 Views)
March is basically over, so let's continue in the April 2013 bug thread.
Message 9 of 9
(10,726 Views)
