BreakPoint
Monthly Bugs, May 2016
Continued from the April 2016 bug thread
 The posting rules are as always:
  • Each post here should only contain a brief description of a bug, together with a link to the thread where it is being discussed.
  • One post/bug!
  • One bug/post!
  • No discussion of bugs. All discussions of a bug must take place in the original linked thread.
(6,671 Views)
CAR#589373
Filed through NI support, so no discussions to link to.  In LabVIEW FPGA, if you use Max & Min with an array, you will get a Xilinx compile error (RTL Elaboration failed).  You will not see the error until Xilinx starts sythesizing.  Found with LabVIEW 2015 SP1 with a Vivado compile.
(6,465 Views)
This thread is now closed.
Continued here in the June thread.
(6,400 Views)
