BreakPoint
Monthly Bugs, November 2014
Continued from the October 2014 bugs thread
 The posting rules are as always:
  • Each post here should only contain a brief description of a bug, together with a link to the thread where it is being discussed.
  • One post/bug!
  • One bug/post!
  • No discussion of bugs. All discussions of a bug must take place in the original linked thread.
Message 1 of 13
(10,233 Views)
As discussed here, the help for "Boolean array to number" is incomplete.
Message 2 of 13
(10,222 Views)
[edited by moderator]
Thanks for pointing this out. It looks like there was already a CAR for this (402163), and I have added it. I plan to post it by the end of the day today. Thanks again!
Best Regards,
Nathan Burke
Product Support Engineer | LabVIEW R&D | National Instruments | Certified LabVIEW Architect
Message 3 of 13
(10,168 Views)
Appearance of silver control is incorrect if increment/decrement buttons are not visible when doing a replacement from another style control.
CAR# 504189
Message 4 of 13
(10,129 Views)
RavensFan wrote:
CAR# 504189
Your link is broken for me
Message 5 of 13
(10,124 Views)
Here is a working link:
http://forums.ni.com/t5/LabVIEW/Silver-numeric-controls/m-p/3042575#M867457
Spoiler
A bug while replacing a control with a Silver one, I would not have discovered that in a million years....
Message 6 of 13
(10,118 Views)
I'm sorry about that.  I should have double checked the link after I posted.  Apparently the HTTP part got stripped off.
Message 7 of 13
(10,071 Views)
Thread
Greetings from Germany
Henrik
LV since v3.1
Message 8 of 13
(9,988 Views)
@Henrik_Volkers wrote:
Thread
2013 bug fixes
361636
Ignore Timestamp property does not work for Mixed Signal Graphs.
Time to upgrade H!
Message 9 of 13
(9,953 Views)
Hovering over a terminal that is a typedef'd cluster of references seems to confuse the coercion context help. It says instead that the terminal is similar to an error cluster, which is definitely not true. (Detailed discussion)
Look at the context help: The wire is pink in the graphic, but olive in the coercion description for "terminal data type".
 EDIT: CAR 480726
Message 10 of 13
(9,917 Views)
