BreakPoint
Monthly Bugs, November 2018
Continued from the October 2018 bug thread
The posting rules are as always:
  • Each post here should only contain a brief description of a bug, together with a link to the thread where it is being discussed.
  • One post/bug!
  • One bug/post!
  • No discussion of bugs. All discussions of a bug must take place in the original linked thread.
(6,938 Views)
@altenbach wrote:
All buttons in the help generate script errors if the help is opened from within LabVIEW. (No CAR yet).
CAR now issued: CAR #718419
(6,904 Views)
Not so much a bug, but an error in the help text:
The Get Image invoke node (used to grab the image of a graph for example) is incorrectly stated as "Available in Real-time operating system" in LabVIEW 2018 (unlike in other versions), which is not the case (well, it might be available on some targets which support having a GUI, like cRIO-9030 for example, but on most systems the node will return an invalid reference error when running as an application on RT targets):
(6,853 Views)
@Mads, please link to the thread where this bug (potential bug?) is being discussed.  This thread is just intended to aggregate other discussions taking place.  That being said, I too suspect that on Linux RT with the embedded UI enabled that this will function properly.
(6,845 Views)
Continued here. This thread is now closed.
(6,768 Views)
First mentioned here
LabVIEW stores information from MyNI.com for the Default data to import into the Application Builder rather than the Data from a Volume Licence Server when a License is checked out from the Volume License Server.
I understand a CAR is forthcoming.  Not a BIG problem until you start deploying a HAL MAL with ppls.  Those builds should have the right (C) info 😉
(6,736 Views)
