BreakPoint
Monthly Bugs, October 2011
Continued from the September 2011 bugs thread
 The posting rules are as always:
  • Each post here should only contain a brief description of a bug, together with a link to the thread where it is being discussed.
  • One post/bug!
  • One bug/post!
  • No discussion of bugs. All discussions of a bug must take place in the original linked thread.
Message 1 of 10
(15,472 Views)
When an event is configured to handle the value change for a numeric control the increment/decrement can get stuck causing a freaky condition where the value keeps changing even after the VI has stopped.
Link.
LabVIEW 2012
Message 2 of 10
(15,450 Views)
Context help window is not updated properly when a new input or output is added to connector pane.
CAR# 318144
Message 3 of 10
(15,429 Views)
Unlike "UDP open", "TCP open" is missing the port output. Oversight?
(details)
Message 6 of 10
(15,420 Views)
In particular, C:\Program Files\National Instruments\LabVIEW 2011\vi.lib\Platform\browser.llb\Open URL in Default Browser (string).vi
CAR# 318137
Message 7 of 10
(15,393 Views)
The display format for the Digitial Display on block diagram constants default to %f, instead of what the control is set to.  CAR# 318263
Tim Elsey
Certified LabVIEW Architect
Message 8 of 10
(15,382 Views)
Starting in LV2009, LabVIEW's handling of variants uses a considerable amount more memory than in 8.6.  Some of my examples show LV using 5 times more memory for the same data set than LV8.6.
CAR 321353
See the thread.
Message 9 of 10
(15,314 Views)
October is basically over, so let's continue in the November 2011 Bug thread.
Thread closed!
Message 10 of 10
(15,278 Views)
