BreakPoint
Monthly bugs, August 2008
IT seems dynamic event registration fails if the respective front panel is not open. Since a corresponding error is generated, this might be an expected limitations.
Still, I cannot find this documented anywhere, so at a minimum it is a documentation bug.
This limitation should be removed if possible or at least be documented in the help for "Register For Events".
See this discussion for an example and more details.
Message 11 of 22
(13,853 Views)
The Get Panel Image method does not include the background image:
http://forums.lavag.org/Front-Panel-Capture-Problem-t11727.html
___________________
Try to take over the world!
Message 13 of 22
(13,805 Views)
As described here
Chilly Charly    (aka CC)
Message 14 of 22
(13,759 Views)
Message 15 of 22
(13,738 Views)
Message 16 of 22
(13,713 Views)
This is either a bug or a feature change.
LabVIEW 8.6 improperly handles Shift+Right Click
shift-right-click on a FP object:
  1. LV 8.5.1 and earlier: >>>>tools palette
  2. LV 8.6 >>>> context menu of object. (same as "no-shift"-right-click)
Message 17 of 22
(13,664 Views)
Entering a free text label on tab control causes label to be entered about 45 pixels higher than cursor position in LV8.6
http://forums.ni.com/ni/board/message?board.id=170&view=by_date_ascending&message.id=352449#M352449
Message 18 of 22
(13,653 Views)
Let's continue all this in the September bug thread. 🙂
Message 20 of 22
(13,614 Views)
