06-21-2010 08:02 AM
Hi All,
I am posting this here first instead of the Idea Exchange as I am confident someone has thought of this already and added it as an idea. I have tried searching for obvious terms but get no hits.
Idea: add some method of navigating back to to the previous "place" in the block diagram, ala Visual Studio.
Typical use case: editing some code, need to copy something similar from another portion of the BD, goto that bit (normally another case in a case structure) copy the code to the clipboard (or ctrl drag it outside the structure to be moved somewhere else) and then quickly jump back to the case I was in previously.
I haven't really though of all the practicalities of this idea yet...
Any body posted this idea yet?
06-21-2010 08:25 AM
Sort of like a bookmark?
06-21-2010 08:37 AM
Sort-of, that is one I did manage to dig up during my search.
My idea is far more tempory, no need to actually create user defined bookmarks etc, LV would do this behind the scenes and then you could quickly move backwards/forwards through the last few. I dont think this info would need to persist if you closed the VI or project.
06-21-2010 08:41 AM
I've been toying with the idea of adding browser-style navigation buttons to my CaseSelect plugin for the JKI-RCF. This will let you step through the State Machine states you've visited. Would this help in your case?
06-21-2010 09:06 AM
Yes thanks Jim that would be great.
A lot of the time I am working within the same VI and just want to go back to the previous state I was in.
06-22-2010 11:05 AM
Jim,
does your plugin work with enums? I can only seem to get it to work with string case-structures.
06-23-2010 05:44 AM
06-23-2010 06:56 AM
Sorry, I must have been on another planet yesterday.
It works fine with enums (I think in a moment of madness I was testing it on the Event Structure) D'oh!
06-24-2010 06:24 AM
What version of LabVIEW do you use? I've got the feature started and would like to share it with you and get your feedback.
