BreakPoint
Obsolete skills
@Ben wrote:
I can see the byte patterns in different forms.
Ben
Picture Ben sitting in front of an array of 9 monitors with green (otherwise incomprehensible) text flowing downwards......
Shane.
Message 11 of 17
(5,056 Views)
Intaris wrote "Picture Ben sitting in front of an array of 9 monitors with green (otherwise incomprehensible) text flowing downwards......"
 "... If you take the red pill you stay in wonderland and find out how deep the rabbit hole goes."  (Morphius)
Ben
Message 12 of 17
(5,053 Views)
Great find!
I guess all that time I spent learning how to fix televisions and VCRs years ago is a little obsolete now.
Then again, it was my interest in electronics that took me to college then eventually into LabVIEW.  Reading LV code is at least a little like reading a schematic.  So maybe it wasn't all wasted time.
Patrick Allen: FunctionalityUnlimited.ca
Message 13 of 17
(4,994 Views)
"  Reading LV code is at least a little like reading a schematic. "
Ditto that.
THat was the first thing that got my interest. I looked at a diagram and thought "I can almost read s this!"
As long as LV is still targeting DAQ and process control, a background as an EE (or physics) is called for more often than a background in comp-sci. "Half-splitting" are circuit works in LV just as well as it does with a physical circuit.
Ben
Message 14 of 17
(4,991 Views)
Your Google Search to find supporting articles finds stuff you have written.
I guess the inverse question that should be applied is "How long do you have to be around to NOT have to cite references?'
Earlier today I found  wikipeadia entry where a citation was required for the claim. Since I was there and actually saw an touched what required a citation, can i cite myself?
No need to answer.
Just thinking out loud.
Ben
Message 15 of 17
(4,091 Views)
I usually cite "myself (private communication)"
Nobody will get this, who am I kidding?
Message 16 of 17
(4,086 Views)
Well,  not all of us are published in peer reviewed journals.  Some are!^^^^
Message 17 of 17
(4,052 Views)
