BreakPoint
Random Posts (An alternate to side discussions)
And as usual...when discussing Ben's garden things go downhill in a hurry.
Message 1401 of 2,258
(12,155 Views)
Well then for something completely different... my most recent prepping project is a hydraulic ram pump.
It operates using "conservation of momentum" using a down hill flow of water to pump water "up hill".
The intent is to use it to harness the flow in the stream at the south end of The Ridge to supply water to the garden at the top of the hill. To date, we have resorted to three methods of watering the garden.
1) Let God water it.
2) run a garden hose through the woods.
3) man-handle buckets up the hill.
Method #1 does a great job most of the time. July and AUgust are the questionalbe months. method #2 has not been used for two years when we had initially planted the trees that will be the orchard. The run is so long and the climb large enough that I get litle water pressure. THe "self-retratcting" hoses start retracting as soon as I start the flow. By The Way, the self-retracting hose do NOT like throns and spikes and will quickly transform into a soaker hose. Method #3 has been mostly my better-half who takes on the role of water bearer.
So I need a better method to get water to the top of the hill. The ram pump does not require any outisde energy source. The efficincy is largely a factor of the ratio of drop from water source to pump to the distance betweeen the water source and the delivery point. Some back of the knapkin calculations indicate I may be able to get 750-900 gallons a day when the stream is running at 2 gal./min.
The basic operation of the pump is...
Water flowing to the pump exits through a check valve (valve to the right in the photo above) and gathers speed and momentum as the flow increases. When the flow is large enough it close the check valve (see the spurt from the right valve in the photo above) creating a water-hammer. The impulse then opens the second check valve which pushes water up into a pressure vessel. The check vale prevents backflow. Once the pump is primed it will automatically cycle and build up pressure in the pressure vessel. preliminary testing shows that it works and will run for hours provided there is a supply of water, and there is some back pressure to keep the pump cycling.
The next step is to add a manifold to allow using three pressure vessels. The additional volume will be need to drive the long distance (100' with about a 40' rise) to the top of the hill.
My eldest G-daughter has already setched out a schemes staring with a small waterfall, some ponds and watering the gardens.
SO......
Not verything goes down hill when talking abotu the garden.
Take care,
Ben
Message 1402 of 2,258
(12,150 Views)
You actually found something good about water hammer.  I'm impressed.  We run all kinds of crazy tests to make sure that our submersible water systems can handle its destructive forces.  Hint:  Not all check valves are created equal.
Message 1403 of 2,258
(12,146 Views)
Short story that may make Snowmlue smile.
My better-half purchased a used ATV (Suzuki King Quad if you are familier with them) and I was trying to learn hwo to operate it last week. Having never driven a motorcycle, I had a lot to learn since it is not like driving a car. I read the manual twice and wnet at it slow but...
While attempting a 3-point turn in my backyard, instead of hitting the front brake (use right hand when backing up) I hit the throttle lever and instantly went into one of those "time slowed down" moments that ended after I slammed the ATV into the back of my house and knocking outa section of cinder blocks that were part of a back porch.
ATV was fine.
Cinder blocks were scheduled to be replaced anyway.
Ben
Message 1404 of 2,258
(12,028 Views)
That ram pump took some effort but it pumped water up hill to my garden for the first time last night.
I had to build a collection pond
Run lines from the pond to the pump
up the hill to the garden
to get about 1/2 gallon per minute
Given the previous method of hauling the water up the hill one bucket full at a time, this is a much improved situation. Since I do most of the gardening and other work, my better half has been the one that resorted to filling buckets and hauling them up the hill. I felt bad watching her have to do that. Now she just has to start the pump, watch the bucket fill and haul it DOWN hill to the garden plots.
If I put in a couple of holding ponds at the top and some drip irigation, she will not even have to do the down hill anymore.
No fossil fuels, no fancy hi tech stuff and EMP proof solutions make me smile.
But I have to confess (don't tell anyone) I would love to add some instrumentation to the hydraulic ram pump becuase the pressure waves inside the pump that get the pump to keep cycling is something I would like to see on a LV front panel graph.
Ben
Message 1405 of 2,258
(11,987 Views)
Ben,
Since the instrumentation is not required to make the pump run, having it there at least for a while does not violate the off-grid premise. One hundred years ago PVC pipe would have been considered fancy hi tech stuff!
Design parameters seem to be scarce.  A quick on-line search only found one equation and a lot of hand-waving. Can you provide any references on quantitative performance?
Lynn
Message 1406 of 2,258
(11,955 Views)
Good point on the PVC. I intend to rebuild it using iron pipe but while completing the proof of concept, I wanted to go with the quick easy light and cheap.
Re: references
I can only offer two low-res photos I took of two pages I found in a Engineering manual that was originall copyrighted circa 1850.
Ben
Message 1407 of 2,258
(11,948 Views)
I have to share this.
https://m.facebook.com/pages/Rothrocks-Kung-Fu-and-Tai-Chi-Academy/97371020515
Go to that link
Scoll down to black belt test 2016
My better is the first person shown. Latter she is shown with the sword.
She passed her test for 4th level black belt in Kung Fu.
Thank you
Ben
Message 1408 of 2,258
(11,876 Views)
Quick note on the ram pump experiment.
I put it to work last night and it did its job, proviing water to The Ridge under dry conditions when the flow in the stream was minimal.
Spoiler
Under normal weather conditions (I do need it to rain occationally ) I should be able to hold up on the hill for about 1.5 years if we can huddle together to make it through the winters.... Not that I am antisocial by any means. Smiley Tongue
If you are looking for me in the meanwhile you will find me tending the garden and I will see Y'all on the other side of TEOTWAWKI !
Smiley Very Happy
Ben
Spoiler
TEOTWAWKI = The End Of The World As We Know It
Message 1409 of 2,258
(11,798 Views)
My sister was giving away a pond to a good home so we had to make one.
It was a lot of work but it was also a lot of good dirty fun. My better-half collected rocks and I did the digging and setting the stones. I hope to run the hydralic ram pump tonight to start the filling.
Ben
Message 1410 of 2,258
(11,743 Views)
