BreakPoint
Requirements Gateway Rules Check
In lieu of an NI Requirements Gateway Forum, I'm using the LV forum for guidance (sorry).
I was having a situation where my rules check showed that I had about 72 uncovered requirements.  I discovered that I was not using the "Add a Cover" line properly.  According to p38 of the NI Requirements Gateway User Manual, in section "Document Covered by Combination of Several Others" there is an AND/OR relationship among the documents depending on how the documents are connected.  Once I changed my diagram to an OR relationship, my uncovered count went from 72 to 1 in the Project Summary window.  However, in the Rules Check, I still see 72 Uncovered requirements.
Does anyone know why the tool would differ in what it displays in these two windows?  I
As far as the reported Uncovered, I've looked at case, extra spaces, spelling, style type, etc and I just don't see why it thinks the specified IDs are not covered.  I used the recommended Word syntax - Requirement_ID and [Covers:Requirement_ID], and the ID is of Style 'Requirement_ID'.
(6,721 Views)
The apology is nice but you might actually want to post to the LabVIEW forum and not this one.
(6,716 Views)
Oops.  Congratulations by the way.
(6,706 Views)
